trouble cornering in the 06
Old Nov 13, 2006 | 12:22 AM
thejucer's Avatar
thejucer
Default trouble cornering in the 06
I have a v6 06 and I used to have an 01 sts that would handle very well. I know it is a rough comparison and I would think the mustang would have an edge in terms of handling, but going around corners at highspeeds if I hit a bump or something in the road my steering wheel loses control for a split second, I think this is called bump steer. What can I do to stop this from happening... realistically and inexpensively... or atleast an explanation...
Old Nov 13, 2006 | 08:12 AM
shifterdelux's Avatar
shifterdelux
Default RE: trouble cornering in the 06
No no, your rear gets loose man.
I too have this problem, after I hit a curb and apperantely my tires (not rims) are not round. So now I need to save up for new tires, and alignment.
While it was good Id still get loose over bumps, but it wasnt too bad. This is because the car is light and you have a live axle. With IRS it be a different story. Thing you could do is apply clutch and brake over bumps, and do it smooth. This is kinda hard with stock pedal positions, especially when you have to go from brake to gas smoothly. Another technique is just back off the gas, but it is best done with backing off the gas, depressing clutch and applying some brake, then getting on gas smoothly.
CS2007
Jun 25, 2019 09:45 PM
chrisdbassplayer
Oct 13, 2015 06:53 PM
2015Ecoboost
Sep 17, 2015 01:48 PM
Sep 8, 2015 11:50 AM
