Latest trick Flow intake... anyone here have it?
Old Aug 19, 2004 | 06:29 AM
Boostnitup's Avatar
Boostnitup
Default Latest trick Flow intake... anyone here have it?
I just installed the latest Trick Flow intake on my '92 LX 5.0 (5 speed car)
This is the breadbox multi-piece design with the "R" lower.
Some things learned... Don't even consider attempting to install this thing without a spacer... you'll never get your distributor cap onto your distributor. Why it doesn't have a spacer with the intake is beyond me. It says you can't use the factory fuel rail... ahem... I did. Surely for a highout put situation crying out for this intake you will want the aftermarket fuel rails, I just haven't gone this route yet... but I will. Using the factory fuel rail and an adjustable fuel pressure regulator in the stock location is a pain... tough to get to in an N/A situation let alone a supercharged scenario.
I'm using it in a supercharged situation... a Novi-1000 with 8lbs boost. Y303 aluminum heads, 30lbs injectors, 75MM throttlebody. Probably the most mismatched batch of parts thrown on a 170K miles 302 HO shortblock but whew... it zips!
Anyone else here step up to the latest intake?
Stone629
The Racers Bench
66
Jun 2, 2016 09:52 PM
Manny92392
Oct 5, 2015 11:39 AM
Sep 24, 2015 09:18 PM
Sep 18, 2015 12:25 PM
Sep 3, 2015 07:14 PM
