HELP! 2nd day screw up.
Hey guys, I am looking for some advice. I got into alittle accident today and I need some adice. The right front corner was hit and the right front tire is completely toe'd. When I drove off it was dragging on the street. I took pics of the wheel and suspension. I would like to know what looks to be my problem. THink you guys could give me a ruff estimate on how much it would cost to fix. THANKS ALOT. BTW, on the exterior shots of the car, the steering wheel is position striaght.
[IMG]local://upfiles/1826/CF0D4F7F876945B3A27DA06EC9D83F54.jpg[/IMG]
[IMG]local://upfiles/1826/EE14FBE7A2FD46498D79742E3AC5A663.jpg[/IMG]
[IMG]local://upfiles/1826/BFD5BF6DED964CB2B1A7107838F08367.jpg[/IMG]
[IMG]local://upfiles/1826/8E830B9900DB4A0CAE6AFB6CD8D53ACA.jpg[/IMG]
the spindle is bent I can see that in the picture.sould not be that much you should also get realigned I would say around $500 tops if some one dose it for you.and you use new parts.all sorry I didnt look at the body just the wheel.price was just for the wheel.now it looks like 1500 to 1800 may be more labor is diff. in all states for body work.a good used fender and light could keep the money down also I cant tell if its into the door or how bad the front cover is.
That is what is busted, Can someone tell me what that is and how much it will be to fix?
thanks
[IMG]local://upfiles/1826/7A7DFA90699443648271E94FD1168AF0.jpg[/IMG]
thanks
ORIGINAL: Richman
thanks
thanks
that plate looking thing is a dust sheld and it may not be broke look at the other side the spindle is bent right where the outter tie rod bolts to it.the shield may be bent you can just bend it around it wont hurt anything just make sure it dont rub on the break rotor.or the shield may be plastic and you would have to replace it.wont be much. even if you didnt replace the shield it would be no big deal.
Boostaddict
Lethal Performance
Sep 8, 2015 09:56 PM
Sep 2, 2015 08:40 PM
