getting longer studs
Old Nov 19, 2006 | 02:51 PM
trance565's Avatar
trance565
Default getting longer studs
about how long does it take to remove the discs, and get to where i can removeteh studs? do i have to remove more than just the brake discs? buddy needs longer studs, which is why im asking. i have a haynes, but it doesnt cover switching out the studs.
Old Nov 19, 2006 | 02:57 PM
patriot98's Avatar
patriot98
Default RE: getting longer studs
For the front expect 10 minutes for each wheel, for the rear its harder, and should be around 30 for each wheel. This is a pain in the @ss job, you will have to pull each stud out, then screw each one into place using lug nut and washers. Then in the rear is when you really start feeling the pain, all thanks to ebrake. Youll know what Im talking about when you get there. For all studs expect to spend half a day on this, minimum. If you drinking it could be the whole day.
EZFEED
May 5, 2016 08:54 PM
Thunderball
15
Nov 22, 2015 11:49 PM
dudeguy421
Sep 24, 2015 11:16 AM
allenmaty
Sep 24, 2015 09:17 AM
8lug
Sep 21, 2015 01:33 PM
