Engine missing..pls advice??
Old Nov 22, 2006 | 08:48 AM
The Jackal's Avatar
The Jackal
Default Engine missing..pls advice??
Hi guys..i washed my stangs engine with littel water with sponge..unfortunatly,when i start the engine there was missinig and vibration while the engine is runing..also the sound of exhoust has changed coz of weeknes of power..wat happend?? pls advice..
Old Nov 22, 2006 | 09:37 AM
Chopper's Avatar
Chopper
Default RE: Engine missing..pls advice??
Water in the spark plug holes is the usual culprit.Remove the COP's and dry them out.
Old Nov 23, 2006 | 11:03 PM
Simon9350's Avatar
Simon9350
I have to agree you got something wet that wasnt supposed to get wet. If its not water in the plugs, you might have gotten the distributor wet although i think it might possibly not start at all if that was the case. If you wrapped your distributor check the wires you might have pulled one loose.
Old Nov 24, 2006 | 01:28 AM
Leeiswho2b's Avatar
Leeiswho2b
I always pressure wash my engine bay. Mine has done this before. Usually I 've just given it WOT and it would clear up after a couple of times. Make sure not to wash your block when it is hot from being ran. It can crack.
Nick Oliver
Oct 17, 2018 04:22 AM
Pyrate Dave
Sep 10, 2015 07:30 PM
raleigh05GTO
Sep 4, 2015 07:09 AM
cbird1177711
Sep 2, 2015 08:51 PM
cbird1177711
Sep 2, 2015 04:12 PM
