I Need Info
Old Nov 24, 2006 | 12:47 AM
hookedonkronik's Avatar
hookedonkronik
Default I Need Info
I own a 1997 V6.
I can only put in about $10 worth of gas at a time because I have a tank leak I need to get fixed. Anyways, I ran out of gas today for the first time ever. I usually run it pretty low (which i know is not good for it) but today it said I had a little bit of gas left and it started putt-putting and eventually died. No check engine light but the battery light came on. I also heard a clunk under my car right before it died. Fluids and all visual parts to my knowledge were fine so I figured I ran out. (I also assume my meter may be a little off now due to the cold weather we've been having - my mileage today seemed to be extremely good..?) So I end up putting gas in it via my brother coming, and it starts up fine. By the way I tried starting it before this and it kept dying.
But to my question...
Now my car is running like poo. Is there anything I should look at that could be damaged? My gas mileage seems to be a bit worse now also. When it get on it, it doesnt have the same pick up it used to before.
Is it bad for my fuel injectors to never get a full tank of gas? I mean im always running on a quarter tank or less. Especially with winter coming this probably makes matters worse.
Any advice on why my car is running like garbage is appreciated alot thanks
Old Nov 24, 2006 | 01:23 AM
ponysnake99's Avatar
ponysnake99
Default RE: I Need Info
its not your fuel injectors you need to be worried about, its the fuel pump, which u may have starved and had under a lot of stress latly, it may just be on its last leg, it depends on what your definition of poo is too...poo as in hesitation or poo as in detonation? try to explain how it runs a little better and we may beable to help a little more
Leeiswho2b's Avatar
Leeiswho2b
I always try to never drive on empty. It is bad for the fuel pump. It will produce more heat and eventually die. Also, another problem is when you have less gas, any particles in your gas tank will be more concentrated and more likely be ran through the fuel system, clogging pump screen/fuel filter/injectors.
Old Nov 24, 2006 | 01:26 AM
hookedonkronik
That all makes sense thanks very much.
And as to the poo remark, i'd say its more towards hesitation than detonation thankfully. Do you think it may start to run a little better with time?
Old Nov 24, 2006 | 09:02 AM
corvetteguy's Avatar
corvetteguy
1996
Fuel Tank
Ford Mustang PERFECT CONDITION GREAT LOW PRICE ! A 060410 $19.95 Marshalls Auto Parts, Inc. USA-OH(Circleville) Request_Quote 1-800-333-2104 Request_Insurance_Quote 423
1995
Fuel Tank
Ford Mustang PERFECT - GREAT LOW PRICE ! A 060094 $19.95 Marshalls Auto Parts, Inc. USA-OH(Circleville) Request_Quote 1-800-333-2104 Request_Insurance_Quote 423
1995
Fuel Tank
Ford Mustang 3.8 A 021306 $19.95 Marshalls Auto Parts, Inc. USA-OH(Circleville) Request_Quote 1-800-333-2104 Request_Insurance_Quote
Old Nov 24, 2006 | 09:54 AM
Archion's Avatar
Archion
one thing most ppl don't realize is that if you constantly run a low fuel level, it increases the chance for rust and leaks, clogging the fuel system. On older vehicles this was easier to fix, but newer vehicles on the other hand, is a little more complicated. Since you have leak already, you need to replace the tank, and more than likely, the fuel pump assy. Not knowing where in ontario you are, here is a list of places that will be able to help you, they manufacture 90 % of all aftermarket steel tanks in north america. They are my old Parent company and can give you a good hookup on what you need.
Ontario Branches
Mississauga
Spectra Premium Industries
5629 McAdam Road
Mississauga, Ontario
Canada L4Z 1N4
Tel. : (905) 501-7685
Fax : (905) 501-9856
Toll free : 800 565-5524
Ottawa
1135 Newmarket
Ottawa, Ontario
Canada K1B 4N4
Tel. : (613) 741-5028
Fax : (613) 741-6819
Toll free : 888 910-8888
Stratford
533 Romeo Street
Stratford, Ontario
Canada N5A 4V3
Tel. : (519) 275-3802
Fax : (519) 275-3809
Toronto
410 Passmore avenue, Unit 5 & 6
Toronto, Ontario
Canada M1V 5C3
Tel. : (416) 609-8780
Fax : (416) 609-9250
Windsor
673 Wellington Avenue
Windsor, Ontario
Canada N9A 6N8
Tel. : (519) 977-7013
Fax : (519) 258-9461
Old Nov 24, 2006 | 02:22 PM
GreyStang's Avatar
GreyStang
ORIGINAL: hookedonkronik
Probably not.. Most car parts stay fugged after they've been abused, even if you start being nice to them lol
Old Nov 24, 2006 | 03:17 PM
rvoss5's Avatar
rvoss5
just a reminder, most mustangs with fuel injection reccomend changing your fuel filter every 15k.
folivier
Tennessee Regional Chapter
Oct 2, 2015 05:32 AM
RCS02v6
Sep 29, 2015 01:46 PM
junior04
Sep 28, 2015 10:53 AM
GLOCKer
Sep 28, 2015 07:36 AM
ThatJuanStang
Sep 25, 2015 08:01 AM
