dumping the clutch fan
Old Nov 26, 2006 | 03:07 PM
angrystick87's Avatar
angrystick87
Default dumping the clutch fan
Just picked up an electric fan at the junkyard yesterday and am looking for any wiring/fuse/electrical advice. I would like it to cut on when I start the car, but to also have the option to let it run after the car is shut down, for the summertime.
I also wonder how much power I will be freeing up by removing the clutch fan when it is going to put more strain on the alternator?
thanks
Old Nov 27, 2006 | 08:50 AM
corvetteguy's Avatar
corvetteguy
Default RE: dumping the clutch fan
why do you want the fan to run after
you walk away from the car?
Are you worried about the car cooling down
to slow?
I would just hook it to switched 12 volts.
Old Nov 27, 2006 | 11:59 PM
Colorado_Mustang's Avatar
Colorado_Mustang
You need a delayed relay. Check a place like DigiKey or Radio Shack and let them know what you want to do. You will be hooked to a 12V switched source as well as a constant 12V source.
I lost idle speed with my electric fans...OEM ones may be more efficient, however. Also, that isn't in comparison to a factory mechanical fan.
ORIGINAL: angrystick87
thanks
BOB ROME
Jul 26, 2023 01:54 PM
PaulH2
20
Jan 31, 2016 09:48 AM
Thunderball
15
Nov 22, 2015 11:49 PM
junior04
Sep 28, 2015 10:53 AM
MacSerio
Sep 27, 2015 01:05 PM
