Wheels and tires???
Old Nov 27, 2006 | 08:26 PM
tuneskies's Avatar
tuneskies
Default Wheels and tires???
I want to do drag style wheels, but I am confused by wheel and tire sizes. I need someone to school me up on the whole thing. I want fat ones in the back and smaller ones in the front without making any difficult mods. Can someone please help me?[8D]
Old Nov 27, 2006 | 11:48 PM
Colorado_Mustang's Avatar
Colorado_Mustang
Default RE: Wheels and tires???
Don't know really what you're asking for, but here's some basic info.
For a tire size of 225/50-16: 225 is the section width in millimeters. Do not confuse this with the tread width, which does not have any indicators in the size of a tire. The 50 is the aspect ratio, which is how tall the sidewall is as a percentage of the section width. IE, a 50 series tire has a sidewall height that is 50% the width of the tire (112.5 mm in this case). And, 16 is the rim diameter.
To find the diameter of a tire, divide the section width by 25.4 to convert to inches (225/25.4=8.858). Multiply that by the aspect ratio in its percentage form (8.858*.5=4.429). Multiply by 2 (you have 2 sidewalls) (4.429*2=8.858). Then, add the rim diameter (8.858+16=24.858).
For rims, you have backspacing, which is a measurement from the inside of the rim to the mounting surface of the center hub. An 8" wide rim with a 4" backspace is a centerline wheel (don't confuse the term with the company). An 8" wide rim with 1" backspace has a very deep dish, while an 8" wide rim with 7" backspace has pretty much no dish.
You also have offset, which is a measurement of the mounting surface in reference to the center of the rim. Positive offset has more backspace, while negative offset has less backspace.
Hope that helps.
robcy
Suspension
Oct 27, 2015 11:14 PM
mmarsh3014
Wheels & Tires
Oct 20, 2015 09:08 AM
Oct 7, 2015 07:02 PM
mungodrums
Sep 28, 2015 05:45 AM
Sep 8, 2015 11:50 AM
