Motor mounts Removel & install????
Old Sep 8, 2004 | 04:43 PM
e40water's Avatar
e40water
Default Motor mounts Removel & install????
Well I gotta get my hands dirty again I see, I am needing alittle help and advice, Whats the best way to remove and install my engine muont on my 83 stang?
Old Sep 8, 2004 | 04:54 PM
Obsol3te's Avatar
Obsol3te
Default RE: Motor mounts Removel & install????
What I'm gonna do is jack up the engine from the oil pan after unbolting the mounts from the k member
then going to remove each mount.
Seems easy enough
Old Sep 9, 2004 | 03:58 AM
USAMuscle's Avatar
USAMuscle
Yeah that's the way to do it. When you jack up the engine, make sure you put a block of wood between the jack and the oil pan so you don't punch a hole in it or dent it.
Old Sep 9, 2004 | 01:35 PM
roundman's Avatar
roundman
It's just as easy to cut a piece of 2 x 4 with a slight curve in it to fit it under the front of the oil pan and jack the motor up from here so as not to take a chance on denting in the oil pan. and loosen all three bolts/nuts on the motor mounts before you jack it up so you do it safely with the motor not jacked up yet. If you don't mind a little vibration transferring into the chassis, you could go with solid metal mounts and loose the flex inherent with the stock mounts too! and you never have to worry about changing them ever again!
Old Sep 9, 2004 | 02:34 PM
e40water's Avatar
e40water
Awsome thanks guys for for youre info, I will get to this job. Thanks alot.
Granatelli Sales
Jan 20, 2020 12:34 AM
musnicki
Sep 23, 2015 07:11 AM
Sep 1, 2015 08:16 PM
kawiguy827
Sep 1, 2015 07:09 PM
