clutch questions
Old Dec 15, 2006 | 02:00 PM
Stella94GT's Avatar
Stella94GT
Default clutch questions
im gussing its the clutch but im not sure. whenever i roll out of 1st, 2nd, or 3rd and get into 2200-2500ish rpm i hear a grinding/rattle type noise comeing out of what sounds like the middle of my car, almost right under and infront of the shifter. any ideas on what that could be or how to fix it?
also any idea on how much it would cost to get my rotors resurfaced?
Old Dec 15, 2006 | 05:25 PM
Poobs's Avatar
Poobs
Default RE: clutch questions
Don't guess. Take it to a shop. Ask then how much to just put the car on the lift and tell you where the noise is.....
Old Dec 15, 2006 | 07:00 PM
GreyStang's Avatar
GreyStang
If the clutch isn't slipping when it's finally fully released then the noise is probably the throwout bearing.
Old Dec 15, 2006 | 09:08 PM
Stella94GT's Avatar
Stella94GT
the throwout bearings huh. are those expenisive or is this noise causing problems do youthink?
Old Dec 15, 2006 | 09:55 PM
GreyStang's Avatar
GreyStang
Usually the throwout bearing gets replaced the same time as the clutch, as they're both in the same area and both wear out evenly. Usually it's the clutch that fries first but sometimes the throwout bearing goes first. How many miles are on your clutch?
Keep in mind I'm just "guessing" it's the throwout bearing, but it seems likely. The bearing itself is really cheap, but to install it you need to drop the tranny, and while your at it might as well replace the clutch too. Shop around for a good price on a clutch job.
Old Dec 16, 2006 | 12:29 AM
Stella94GT's Avatar
Stella94GT
thanks any ideas help. um theres less than 30k on the clutch. mabye ill take it to get looked at when the weather gets nicer out.
AmericanMuscle4.6GT
Nov 10, 2015 02:06 PM
MasterLanMan
Sep 13, 2015 08:21 PM
Boostaddict
Lethal Performance
Sep 8, 2015 09:56 PM
raleigh05GTO
Sep 4, 2015 07:09 AM
