Help! Rebuild kit questions.
Old Dec 16, 2006 | 08:11 PM
87ragtop's Avatar
87ragtop
Default Help! Rebuild kit questions.
Hey found a rebuild kit off a local shop for about $300 USD With piston rings (Perfect Circle), rod and main bearings (Clevite), gasket-set (Victor-Reinz), 3 peice timing set (Cloyes), oil pump (Melling), pistons (Sealed Power), and freeze plugs (Pioneer). Is this kit anygood? Also it's simply stamped 302 Ford 1986-1990. How can I be sure they are for the HO and not the standard 5.0? Or are all these parts interchangable with no drawbacks? Just want the best for my new toy....
Old Dec 16, 2006 | 08:16 PM
mustnglvr's Avatar
mustnglvr
Default RE: Help! Rebuild kit questions.
Sounds like a good kit for a rebuild. Clevite makes really good bearings.
Old Dec 17, 2006 | 03:27 AM
87ragtop's Avatar
87ragtop
I dont know if the kit os for a HO tho, are the pistons and timing set the same for both? As far as i have heard all that is different between HO and non-HO is the cam, crank, fring order and the intake manifold, but i may be wrong.... will this kit work?
Old Dec 17, 2006 | 07:25 PM
mustnglvr's Avatar
mustnglvr
If you got a kit for the correct year you are working on, yes the kit will work.
Lethaldosage423
Oct 19, 2015 12:12 AM
Dathan
Oct 5, 2015 05:52 AM
Drastang
Sep 30, 2015 03:48 AM
treesloth
Sep 28, 2015 07:03 AM
