Squeaking Brakes
Old Sep 10, 2004 | 03:23 AM
grannystang's Avatar
grannystang
Default Squeaking Brakes
Need some advice...my husband did a break job on my 2000 Mustang (V6) about 4 months ago. The darn things squeak more than ever now and get some serious black brake residue on the rims. Any ideas on what is causing this? Did he screw something up??
Old Sep 10, 2004 | 04:21 AM
e40water's Avatar
e40water
Default RE: Squeaking Brakes
Was their any brake pad shims installed on the front Pads? some times they cause squeals, Their is some brake squeal spray you can buy at the auto parts store called Stop squeal.
Old Sep 10, 2004 | 02:59 PM
vfast's Avatar
vfast
I ♥ Acer
sometimes a nice hit with a hammer to snug them up on the caliper is need also....some of the squeaking came be from the brake dust....I think he put on so carbon brakes which led to alot of dust....
Old Sep 10, 2004 | 03:16 PM
mdvaldosta's Avatar
mdvaldosta
I ♥ Acer
Most brake sqeel comes from either caliper to pad vibration (shims or ant-sqeel compound will clear this up) or from the brake pad anti-rattle clip hardware. Your "supposed" to change those clips each brake job but no one ever does - at least put some grease there to keep the sqeel down if you re-use them. Also if you don't turn the rotors during a brake job often times the pads won't seat well with the rotors and the mis-aligned grooves between the surfaces will cause the brake dust to crystalize in those groves causing sqeels too.
b8checker
Oct 8, 2015 12:55 PM
Matt's 95 Stang
Oct 5, 2015 07:16 AM
guitarman376
Sep 30, 2015 05:54 PM
Sep 25, 2015 06:42 PM
ThatJuanStang
Sep 25, 2015 08:01 AM
