spring installation help
Old Dec 19, 2006 | 05:33 PM
6charger8's Avatar
6charger8
Default spring installation help
What the hell. I just spent 2 hours trying to get out one of my front springs. No luck, even trying to use a spring compressor. I have an 03 GT and am trying to install a eibach pro kit. Any tips or helpfull links?
Old Dec 19, 2006 | 07:38 PM
amrcnidyot's Avatar
amrcnidyot
Default RE: spring installation help
everything you need to know here
Old Dec 19, 2006 | 10:33 PM
bobbyward's Avatar
bobbyward
if you took the sway bar and spindle loose from the aframe nothing
else holds it in ? once the aframe drops you will have to pop it out
of the spring pocket , make sure you have a jack under the aframe before you take that stuff loose although
Old Dec 20, 2006 | 12:43 AM
v6stang07's Avatar
v6stang07
+1 on that how-to, exactly how i did mine
Old Dec 20, 2006 | 03:18 AM
Colorado_Mustang's Avatar
Colorado_Mustang
I took off the lower A-arm at the hinge point and it worked well. It's the Hayne's/Chilton method and you don't have to worry about your alignment being too far off (mine was still in spec, just on the edges instead of the middle).
Old Dec 20, 2006 | 03:38 AM
OnyxCobra's Avatar
OnyxCobra
do you guys really think taking off the brake caliper and dropping the strut is the easiest/best way? I just popped the ball joint and the spring comes right out. [sm=feedback.gif]
Old Dec 20, 2006 | 08:46 AM
sandcracker21's Avatar
sandcracker21
ya, springs can be a pita, i remember mine! oh my god, it seems that more ppl
run into CRAZY problems with springs then with anything else....except maybe headers
well good luck, and follow that write-up, i followed basicly the same one
Old Dec 20, 2006 | 11:03 PM
bobbyward's Avatar
bobbyward
i have done it both ways and really it is about the same time either way,if you have air tools its just 2 seconds to zip off the cauliper
the only thing i don't take it loose at the top as that can change your
front end alignment, i just take off the nut in the center , with air to remove the strut just for extra working room is worth it sometimes also , i have a electric impact also and that worksget also, after you have changed them a couple dozen times it becomes second nature !
only thing i see is when just one side is up it causes problems with the sway bar preloading ?
mtgldr
Feb 3, 2024 09:00 PM
PullTab
Oct 30, 2015 08:46 AM
Luke9222
Sep 4, 2015 06:46 AM
Sep 1, 2015 08:16 PM
