65 mustang wont turn over ...
It's on your fenderwell. It's a Ford, afterall. You have2 options to get the starter to spin.
1. Short the 'S' terminal to the battery '+.' That will rule out the ignition switch and verify it is the solenoid or not. And, you don't need much current carrying capacity in the jumper.
2. If shorting the 'S' doesn't work, you can short between the 2 big terminal (from the battery to the starter, basically). You'll need something that can take a lot of juice to do this. I've done this with a pair of pliers in a pinch, but make sure you don't get in the way of that 100+ amp surge.
ORIGINAL: socal012
Not sure ... I will check tomorrow.
thanks for the fast reply.
KEM Motorworks
Aug 14, 2015 10:13 PM
