how wide can i go????
Old Dec 23, 2006 | 07:50 PM
sweet99's Avatar
sweet99
Default RE: how wide can i go????
ORIGINAL: jacrockettI'm going to take my 275's from the rear, mount them up front, and go try some corners and bumps. That ought to answer the question.People talking about rim diameter as if it applies to tire diameter crack me up. Tire diameter is rim + tire sidewall (width x sidewall aspect ratio).e.g. 275/35R17 tire has a 275mm x .35 sidewallYou can get tires for a 20" dia wheel that ars the same outside diameter as a tire for a 17" wheel
Well you asked how wide you could go on a 9" wide wheel. You did not say you were staying with the same width which would change the overall diameter(if you went with a wider tire) right? Then you might have an issue with the 18" wheels, especially with the car being lowered and by how much? That's why I suggested the forum for the year of your car as you would most likely find guys with what you are trying to accomplish there. When I asked about 275/40-17's up front I was told they would fit and with really cranking the steering wheel I would keep the swat bar clean! LOL Also a 20" wheel with the same outside diameter as on a 17" wheel would have it's limits. What would be the sidewall of a tire with the diameter of the 275/35-17 you mentioned? I came up with a sidewall of almost nothing, 20mm I think. Check my math there would you? Anyways hope it all works out for you. Try checking out the look of a 315/35 from the back on a Stang! I love wide tires! Mark
Old Dec 24, 2006 | 12:56 AM
v6stang07's Avatar
v6stang07
275's fit on a new edge, thats what i run and my front has been lowered a full 1.5". i have very slight minimal rubbing when i fully turn to the right which i only do occationally when i park. its just the edge of the tire rubbing on my sway bar. no biggy at all, and it very rarely happens. 275's max up front and 325's max out back. period
Old Dec 24, 2006 | 01:40 PM
jacrockett's Avatar
jacrockett
ORIGINAL: v6stang07
Thanks. Let's see if Santa can bring me 4x BFG-KD's 275/35R17 =)
Old Jan 19, 2007 | 02:41 AM
prostallion 347's Avatar
prostallion 347
i have a 94 gt with saleen wheels on it18x9 on the front with a245/40/18 and the rear 18x10 with a 295/35/18 i have no problems clearing these tires
mmarsh3014
Wheels & Tires
Oct 20, 2015 09:08 AM
mungodrums
Sep 29, 2015 09:18 PM
mungodrums
Sep 28, 2015 05:45 AM
Sep 8, 2015 11:50 AM
Sep 1, 2015 08:16 PM
