air pump delete??????
Old Dec 22, 2006 | 08:54 PM
DirtyDave95's Avatar
DirtyDave95
Default air pump delete??????
OK i have a question, my air pump is going out and its starting to make noises, everything that i need the air pump for is disconnected. My question is what belt would i need to bipass the air pump, and also does anyone have a routing diagram for the belt after the airpump is gone?
Old Dec 23, 2006 | 09:02 AM
corvetteguy's Avatar
corvetteguy
Default RE: air pump delete??????
Cost you more for a belt
1990
Air Pump
Ford Mustang(8-302, 5.0L)-C121P$20Davis Auto Center, Inc. USA-VA(New-Church) Request_Quote 1-800-446-8544 Request_Insurance_Quote
1989
Air Pump
Ford Mustang(8-302 5.0L)OHS173$20Old Dominion Auto Parts USA-VA(Roanoke) Request_Quote 1-800-227-7315 Request_Insurance_Quote1990
Air Pump
Ford Mustang-8-302 (5.0L)-06B041$25Robbin's Auto Parts USA-NC(Henrietta) Request_Quote 1-800-726-0275 Request_Insurance_Quote
Old Dec 23, 2006 | 07:59 PM
Poobs's Avatar
Poobs
Will the car even run without an air pump ? What will the O2 sensor do if the air in not injected ?
Old Dec 24, 2006 | 04:05 AM
P.S.I.cho's Avatar
P.S.I.cho
yes the car will run without the air pump, it will also free up some of the load on the engine but raise your emissions, so if u have emissions i would not recomend deleting this air pump, as for belt size route a string around all of your pulleys except the air pump, measure the string count the ribs in the old belt, and go to napa or any parts store and they should be able to find one for you. also its a little more expensive but u can get an air pump delete idler pulley from summit. dont forget to plug any vaccume lines that may be left open or you will be chasing a high idle
Old Dec 24, 2006 | 06:42 PM
Poobs's Avatar
Poobs
No CEL by bypassing the air pump ?? I think I'm going to try it .....
2007CalSpec
Dec 13, 2020 11:42 AM
9550
Oct 26, 2015 05:01 PM
ctgreddy
Sep 20, 2015 08:35 PM
Camster
Sep 10, 2015 11:18 AM
Webster454
Sep 7, 2015 04:59 AM
