which grade oil to use?
Old Dec 24, 2006 | 11:03 PM
mitmaks's Avatar
mitmaks
Default which grade oil to use?
Here's my engine build 306 mexican shortblock with forged rods and pistons (9to1), moly rings, steel main girdle all ARP hardware, fluidampner, double roller t-chain with TFS stage 2 cam, moroso 1 piece pushrods, TFS 1.7 roller rockers, TFS R heads box stock, TFS R intake box stock
along with D1SC ProCharger set at 16psi
Which grade oil should I use?
Old Dec 25, 2006 | 04:49 PM
sandcracker21's Avatar
sandcracker21
Default RE: which grade oil to use?
what exactly makes your engine "mexican"?
lol
Old Dec 25, 2006 | 07:35 PM
Chopper's Avatar
Chopper
The choice of lube oil is as much based on the design of the engine as bearing clearance.The oil has to get to the bearings as soon as possible upon start-up so I would use 10w30.Maybe even as low as 5w30??
I would avoid synthetics for the first 500 miles but after that you can switch to a full synthetic.
Old Dec 25, 2006 | 11:45 PM
mitmaks's Avatar
mitmaks
ORIGINAL: sandcracker21
lol
open up www.google.com and type in 306 mexican block. Good luck on your research
Old Dec 26, 2006 | 01:11 AM
WhiteFoxGT's Avatar
WhiteFoxGT
Resident Ford Troll
I use regular old Castrol GTX 5w30 in my 306..
wraith777
Sep 28, 2015 10:49 AM
belam
Oil and Oil Related Topics
Sep 23, 2015 11:29 PM
Demodulates
Sep 18, 2015 11:14 AM
Sep 17, 2015 07:57 PM
kevsgt
Sep 9, 2015 06:20 AM
