351C equipped?
Old Sep 15, 2004 | 05:56 AM
FoxGT's Avatar
FoxGT
Default 351C equipped?
What all common cars do you know of with a 351 Cleveland? I don't need to know cars that are impossible to find like the pantera or bricklin.
Old Sep 15, 2004 | 12:03 PM
roundman's Avatar
roundman
Default RE: 351C equipped?
They aren't common anymore! some Stangs, Torinos, and other late 60's to mid 70's Fords came stock with them. Personally I think the 351C is overrated and you can do just as good and be more reliable with 351W. Parts are much more readily available and much cheaper too for the Windsor engine.
Old Sep 15, 2004 | 02:33 PM
94Cbra's Avatar
94Cbra
Yeah, I'm with roundman. The Windors are IMO better than the Clevlands. The 351W is a tougher block than the 289/302, but has the same bore spacing and bore diameter so heads retrofit. 302 HO and 351W use the same fireing order 2 so cams can be exchanged as well. Basicly what im saying is that it will be a lot cheaper and easier to build a Windsor than it will be a Cleveland. Like roundy said, it will be more reliable, too its power capabilities are better than a Cleveland due to the huge aftermarket.
Old Sep 15, 2004 | 08:31 PM
matthockey32's Avatar
matthockey32
I ♥ Acer
why do an engine swap? stroke and poke the 302 to 347 and whip some ***.
Old Sep 15, 2004 | 09:11 PM
luckythirteen13's Avatar
luckythirteen13
the 351 will last longer then a 347. also, the 347 cant rev as high
Old Sep 16, 2004 | 09:41 PM
FoxGT's Avatar
FoxGT
Just for knowledge of what cars its in guys. I have no intention of using a 351c. I'm going with a 351W a little later on.
JoshyGT
Sep 19, 2017 08:52 PM
mustangheaven
Jan 3, 2016 11:20 AM
mustangheaven
Oct 7, 2015 10:23 AM
mustangheaven
Sep 29, 2015 11:00 AM
Big Al's 03
Mach 1 Section
Sep 21, 2015 07:59 AM
