were is the ecu
Old Sep 16, 2004 | 09:41 PM
nywc's Avatar
nywc
Default were is the ecu
Im getting the jet chip for my 02 roush, were is the ecu located
Old Sep 16, 2004 | 09:51 PM
2001_SaleenS281_08's Avatar
2001_SaleenS281_08
Default RE: were is the ecu
wow, hey welcome to the boards! nice car! I'll let sum1 else take the question though
Old Sep 16, 2004 | 09:55 PM
mdvaldosta's Avatar
mdvaldosta
I ♥ Acer
Passenger kick panel, under the dash. Remove the door sill plate and the kick panel and you will see it. Remove the 3 wire harnesses blocking access to the ECU, then 1 bolt to remove 1 side of the plastic retainer holding it on and 1 bolt to remove the ecu harness then remove the ECU.
Old Sep 17, 2004 | 12:33 AM
nywc's Avatar
nywc
Thanks for the help, How do those power pullies work??
Old Sep 17, 2004 | 12:46 AM
mdvaldosta's Avatar
mdvaldosta
I ♥ Acer
slowing your accessories down by about 25% ... their good for about 5-6 rwhp
Old Sep 17, 2004 | 07:18 AM
92BOOSTED's Avatar
92BOOSTED
Dont forget to take the ground cable off of the battery before you unplug the ECU."Yes ground ,not the positive".
Rye
Old Sep 18, 2004 | 10:23 AM
vfast's Avatar
vfast
I ♥ Acer
question?..wht speend 250-350 for than chip? a new pms will set you back 900 but you can have unlimit tunes and don't have to find a place to burn another one..do some research on some of the stand alones
bryan616fl
Jan 25, 2019 09:07 PM
Meystang
Sep 25, 2015 04:05 PM
rksnow1
Sep 14, 2015 08:46 PM
angeljoelv
SVT Forums
Sep 10, 2015 09:12 PM
adamfrosceno
Aug 27, 2015 07:40 AM
