fuel regulator??
Old Dec 29, 2006 | 02:14 AM
bds95stang's Avatar
bds95stang
Default fuel regulator??
i am doing a EFI to carb swap and i know the EFI fuel pump has wasy to much pressure to run with a carb. do i need to drop the tank and replcae the fuel pump or is it possible just to get a regulator for it to reduce the pressure??
Old Dec 29, 2006 | 02:32 AM
Colorado_Mustang's Avatar
Colorado_Mustang
Default RE: fuel regulator??
Replace the pump and get a regulator. I use an Edelbrock electric pump with a Holley by-pass regulator.
Old Dec 29, 2006 | 02:35 AM
Jugador's Avatar
Jugador
i think you'd need to run a return to the tank with a stock electric pump because the regulator is going to be dropping the fuel pressure a lot and it will have a tendency to flood the motor if you can't send excess gas back to the tank
Old Dec 29, 2006 | 02:39 AM
Colorado_Mustang
Don't have to have a return line. The regulator will only allow so much fuel to pass. A by-pass regulator like I have just gives consistant line pressure vs. the returnless style regulator.
ORIGINAL: Jugador
Old Dec 29, 2006 | 12:39 PM
bds95stang's Avatar
bds95stang
so i do need the new pump too then? thats what i figured but i was just making sure. tyring not to spend money where its not necessary.
Old Dec 29, 2006 | 07:30 PM
Colorado_Mustang
New pump would be necessary.
GimpyHSHS
19
Dec 19, 2023 01:12 PM
mrtrodonet
Sep 19, 2020 03:12 PM
Sixx
Oct 5, 2015 07:36 PM
svfetter
Oct 5, 2015 11:39 AM
mrappe
Sep 26, 2015 10:16 AM
