Battery shut off switch????
Old Sep 21, 2004 | 03:12 PM
thelast50ho's Avatar
thelast50ho
Default Battery shut off switch????
I relocated the battery to the trunk of my car a while back and i was wondering if i needed a switch on the back of my car in order to run at the strip. I ran it at my local drag strip once before but it was real busy that night and the tech inspectors didnt look it over that well. Any imput would be great. [sm=thanx.gif]
Old Sep 21, 2004 | 10:21 PM
roundman's Avatar
roundman
Default RE: Battery shut off switch????
Yes, you do need a rear mounted battery shut off switch that shuts off the entire car while it is running as this is how they check them. You need to relocate the alternator charging wire back to the postive post on the battery so the engine can't run on after the battery switch is thrown to OFF or they will not pass you in tech. And if you don't have a trunk, the battery needs to be mounted in an approved battery box which is sealed and vented to outside the car with a of two hold downs, minimum hold down size is 3/8" diameter threaded rods too. hope this clears it up for you.
Old Sep 22, 2004 | 12:17 AM
thelast50ho
thanks, im goin to the track tomarrow. i hope they dont notice that the battery is in the trunk un till i get a chance to put a switch on it
BOB ROME
Jul 26, 2023 01:54 PM
4cylinderplus2
Oct 9, 2020 07:45 PM
lincolnshibuya
Jul 5, 2020 03:05 AM
guitarman376
Sep 30, 2015 05:54 PM
logan409
Sep 26, 2015 07:43 PM
