failed smog
Old Sep 22, 2004 | 02:27 AM
luckythirteen13's Avatar
luckythirteen13
Default failed smog
my dad's car just failed smog at 15mph (1908rpm)
it says: NO (PPM) max is 517 and he got 536
how would he get this number down. you think sense its so close an oil change would do it. its been at least 6K sense the last oil change. im doing the oil tomorrow but is there anything else.
every other part of the test was perfect.
Old Sep 22, 2004 | 02:32 AM
redshadow02's Avatar
redshadow02
Default RE: a little off subject....
ryan i need to say something
Old Sep 22, 2004 | 03:29 AM
94Cbra's Avatar
94Cbra
redshadow is dumb as hell
Old Sep 22, 2004 | 03:43 AM
luckythirteen13
anyone with something serious to contribute?
Old Sep 22, 2004 | 02:23 PM
Dan04COBRA's Avatar
Dan04COBRA
Do you mean NOx...
If you do, it's so close he could just retard the timing alittle and that should get him through. NOx is generally a Cat/O2 problem...
Old Sep 22, 2004 | 09:11 PM
Redline03GT's Avatar
Redline03GT
Pour some of that "Guaranteed to pass emmissions" fluid in his tank. Always works for my dad, and his truck has 200,000 miles on it.
Old Sep 22, 2004 | 09:50 PM
vfast's Avatar
vfast
I ♥ Acer
well replace the PVC, tune up, back the time off about 5 degrees, hotter stat. make sure all vacuum lines are not leaking..if these don't work then look at the o2 sensor then the converter
Old Sep 22, 2004 | 10:57 PM
Dan04COBRA's Avatar
Dan04COBRA
He's so close that I just think pulling some timing would handle it, make sure you let the car get warmed up good the next time you have it inspected.
Old Sep 22, 2004 | 11:09 PM
matthockey32's Avatar
matthockey32
I ♥ Acer
try some fuel injector cleaner, premium gas, tune-up and simple stuff.
Old Sep 23, 2004 | 02:44 AM
roundman's Avatar
roundman
you could always ask them to check the calibration on their instrument also as that is damn close to be OK.
