tailights dont work
Old Jan 6, 2007 | 05:09 PM
leeroy's Avatar
leeroy
Default tailights dont work
taillights dont work all other lights work fine 89 gt any suggestions would be apreciated
Old Jan 6, 2007 | 08:00 PM
sprostang's Avatar
sprostang
I ♥ Acer
Default RE: tailights dont work
You did check the fuses right?
Old Jan 6, 2007 | 10:21 PM
Sacmo's Avatar
Sacmo
Have you checked the bulbs??? Just starting with the obvious...
Old Jan 6, 2007 | 11:10 PM
hot wheels's Avatar
hot wheels
last summer i had a problem with my taillights. did all the normal checking, bulbs, fuses, ect...then i took one of my tailight assemblies off and found that one of the wires had been pinched between awasher and the body (from the factory). spliced it back together, put the tailight back on carefully and everything works perfect. oh, the fuses kept blowing so i figured there had to be a short somewhere and that pinched wire was the cause. just took 5 years to work through the wire.
Old Jan 14, 2007 | 12:43 PM
cease4's Avatar
cease4
ok first thing u should do is obviously check ur light bulbs and fuses now if they all look good u can always test the connector where ur light bulbs go...now if all of that works it can be ur brake light switch its located under ur brake pedal it controls ur brake lights and all that good stuff....if not u might have a burn wire or circuit malfunction just check that out usually thats the problem.......
Old Jan 14, 2007 | 07:09 PM
hot wheels's Avatar
hot wheels
what the hell is a "burn wire"?
Old Jan 18, 2007 | 12:08 AM
cease4's Avatar
cease4
wat i was trying to say was that one of the wies made bad contact and got burned in oder words it melted and messed up the connection
Old Jan 20, 2007 | 08:33 PM
fountainofpain's Avatar
fountainofpain
the other day i was driving and hit a slight bump then the interior lights came on, so igot out and checked the tails and sure enough they were on. so now whenever i put the headlights on if i play with the switch the interior light come on. so im guessing its the switch that probably has bad connection, but im not sure if a bump would make it work.
Pyrate Dave
Sep 10, 2015 07:30 PM
96stang3.8
Sep 10, 2015 06:42 AM
JoshyGT
Sep 7, 2015 02:04 PM
cbird1177711
Sep 3, 2015 08:43 PM
Sep 1, 2015 08:16 PM
