Heater
Old Jan 10, 2007 | 02:04 AM
aftlcc's Avatar
aftlcc
Default Heater
It just got cold in Mid GA and I found out this morning on my way to school that the heater SUCKS! Is this a common problem with Fox cars? And does anybody have any suggestions? It was a thirty minute drive and was still COLD when I got to school...
Old Jan 10, 2007 | 03:01 AM
Colorado_Mustang's Avatar
Colorado_Mustang
Default RE: Heater
Fox bodies are usually very hot with the heaters. You either have some heater duct work not working or the thermostat is stuck open. Did the engine temp go up?
Old Jan 10, 2007 | 09:38 AM
corvetteguy's Avatar
corvetteguy
Default RE: Heater
On my 89 GT I had to go through 2 thermostats in 1 year.
"Always buy the expensive one".
You can tell if it is working by:
Starting cold and closely watching T gauge.
In 5 minutes it should start to rise.
It should go to just below the 270 and (like overheating)
Then it should drop pretty fast to mid range.
At this point you should have heat.
PLAYING IN THE SNOW
Old Jan 10, 2007 | 02:01 PM
GreyStang's Avatar
GreyStang
Default RE: Heater
I've had 4 Stangs so far, & good heaters in all of them. You must be having a problem with yours
Old Jan 10, 2007 | 09:59 PM
Colorado_Mustang
Default RE: Heater
You should have heat well before the thermostat is shown to open on the temp gauge. Even 100* fluid going through the heater core will provide warmth. I'm usually turning down the heat when the gauge reads 150*.
ORIGINAL: corvetteguy
Old Jan 11, 2007 | 01:21 AM
aftlcc's Avatar
aftlcc
Default RE: Heater
The temp gauge works fine and the motor doesn't run too hot or cold. I haven't had much time to look at cause my hours at work. I'll take a look at the ducts this weekend. Thanks for the tips
Old Jan 11, 2007 | 02:41 AM
nitrousjunkie347's Avatar
nitrousjunkie347
Default RE: Heater
sounds like it could be the heater core. If thats the problem, only way I know of to replace it is to pull the dash out.
Old Jan 11, 2007 | 09:32 AM
GreyStang's Avatar
GreyStang
Default RE: Heater
If they motor isn't overheating, and the heater blower motor is working fine (you can hear it, right?) Maybe the hot/cold flapper valve is either stuck or the cable leading to it is broken. Or yea the heater core might be clogged
Old Jan 11, 2007 | 12:14 PM
aftlcc's Avatar
aftlcc
Default RE: Heater
thanks for all the tips guys. I'll dig into it on Saturday. I hope this fixes it, its gettin too cold for me...
Old Jan 11, 2007 | 02:11 PM
88droptopgt's Avatar
88droptopgt
Default RE: Heater
Mine chases me out of the car!
