93 gt coolant leak
Old Jan 13, 2007 | 01:06 PM
marcin2323's Avatar
marcin2323
Default 93 gt coolant leak
I was wondering of anyone can help me i just got a 93 gt and upon driving it home a leak developed i changed to water pump all the hoses and the leak is still there it seems to be dripping by the oil pan on the left side of the motor, any ideas?????
Old Jan 13, 2007 | 11:21 PM
kenv's Avatar
kenv
Default RE: 93 gt coolant leak
I was just reading today that a coolant leak from the rear of a 4.6l could be coming from a heater hose, & that to replace it you have to pull the intake. Not sure if thats your condition, but that should be a "fun" project if it is.
Old Jan 14, 2007 | 12:46 AM
marcin2323's Avatar
marcin2323
thaks for the info but its a 5.0 and i really got a project on my hands it coming from the timing chain cover
Old Jan 14, 2007 | 03:01 PM
Colorado_Mustang's Avatar
Colorado_Mustang
Since you'll be taking the timing chain cover off, it'd be a good time to replace the timing set with a good double roller. Timing chains wear/stretch over time and alter the timing a couple degrees. It'd also be a good time for a cam upgrade if funds allow...
Old Jan 15, 2007 | 01:00 AM
kenv's Avatar
kenv
ORIGINAL: marcin2323
Oops! sorry, I should have noticed that it was a `93, my bad
Old Jan 15, 2007 | 03:47 PM
kartracer55's Avatar
kartracer55
Where a leak is visbile and where a leak is actually comming from are two different things. Clean the area off, and see if a local auto parts chain does tool rentals. Rent a pressure tester, pressure test the system, and diagnose. Otherwise you could be on a wild goose chase for the leak needlessly spending money.
Jim
Old Jan 15, 2007 | 04:02 PM
kartracer55
ORIGINAL: kenv
The heater cores themselves actually leak too. I work on alot of crown vic's (p-71's). If the 4.6 motors are set up the same, the hoses arn't THAT bad. You dont need to pull the intake but small hands help in getting them off. Now, to replace the heater core... THAT's a whole different beast.
Old Jan 16, 2007 | 08:37 PM
Rizza757's Avatar
Rizza757
hey whats up man i would take a close look at the freeze plugs on that side.it is very common for build up to occur behind the plugs and rott them from the inside out.like i said look close.look for coolant trails.
4cylinderplus2
Oct 9, 2020 07:45 PM
bradleyb
Nov 27, 2015 07:50 PM
jerrytubes
Oct 23, 2015 12:11 PM
bradleyb
California Regional Chapter
Oct 1, 2015 01:02 AM
wraith777
Sep 28, 2015 10:49 AM
