new valve covers
Old Sep 30, 2004 | 02:10 AM
luckythirteen13's Avatar
luckythirteen13
Default new valve covers
im looking at these http://store.summitracing.com/defaul...&Ntt=mor-68202
also http://store.summitracing.com/defaul...&Ntt=mor-68660 and http://store.summitracing.com/defaul...&Ntt=mor-68740
my question is, what about that tube that runs from the front of the tb to the top of the oil filler tube? does the air go from the tb to the valve covers? bobby suggested i use a breather to cover the whole you put oil in and then take it off when its time to put in oil...will this work? will the breather i posted work for that? do i just plug up the hole at the tb?
Old Sep 30, 2004 | 02:15 PM
roundman's Avatar
roundman
Default RE: new valve covers
the tube from the throttle body lets filtered air enter the crankcase so the PCV valve can draw the blow-by gases out of the crankcase back into the intake manifold where they get burned. You can go with the breather caps you show and they will do the same thing, just not as fine a filter as the normal air cleaner is. and yes, you pop one out to use to put oil in the motor. and yes, just plug up the hole at the throttle body if you don't use it anymore.
Why are you going with the tall valve covers by the way?? Just curious.
Old Sep 30, 2004 | 02:36 PM
luckythirteen13
im going with tall valve covers cause summit, afr, and the local speed shop all said that the roller rockers wont fit under the stock covers
GimpyHSHS
19
Dec 19, 2023 01:12 PM
mrtrodonet
Sep 19, 2020 03:12 PM
winner99
Oct 1, 2015 01:06 PM
Boostaddict
Lethal Performance
Oct 1, 2015 08:58 AM
Boostaddict
3.7L V6 S550 Tech 2015 - 2017
Oct 1, 2015 08:57 AM
