Voltage Drop
Old Sep 29, 2004 | 11:53 PM
DriftAngle45's Avatar
DriftAngle45
Default Voltage Drop
my 2.3L is having problems at keeping the voltage up. I put in a new 80 amp alternator and a new battery with CA 1000 CCA 800 and run time of 130 mins. thinking it was one of those two. well I put them in and it runs better but the voltage is still running short. I disconected all the accessories like my stereo and alarm, thinking that would help. if anybody can help me and give me an idea that would be great. when I have the car on, with headlights on and hazards and the A/C the car just about shuts off. if that helps any.
Old Sep 30, 2004 | 09:59 AM
horseshoeing's Avatar
horseshoeing
Default RE: Voltage Drop
Where did you get your alternator? If you got it from a chain store , it might be bad.
Old Sep 30, 2004 | 02:07 PM
roundman's Avatar
roundman
also check your battery and ground connections to make sure they are clean and tight and free of any corrosion as this will kill the voltage too. if the cables show any corrsosion on the ends, you probably ought to replace them too. any auto parts store can check you charging system right on the car too, so take advantage of this service at the nearest local one who does this like Auto Zone or Advanced Auto, etc. etc.
Old Sep 30, 2004 | 03:02 PM
jdaniel's Avatar
jdaniel
I ♥ Acer
Sounds kinda like a grounding problem to me. Better watch out, you could fry everything on the system.
jwog666
Dec 27, 2021 08:09 PM
88 orangepeel notch
Oct 5, 2015 09:03 AM
Matt's 95 Stang
Oct 5, 2015 07:16 AM
TfcCDR
Sep 14, 2015 12:08 PM
wilsonro
4 Cylinder NA and Turbo
Sep 11, 2015 07:13 AM
