front trans pump seals Help!!!
Old Jan 14, 2007 | 07:29 PM
Rizza757's Avatar
Rizza757
Default front trans pump seals Help!!!
Hi everyone i have a problem and need some advise.i have a 1990 mustang gt Aod transmission.I recently installed a edge racing 3000 stall converter.When it was installed i went ahead and replaced the rear main seal as well as the front pump seal on the trans.Reinstalled the trans and ran it,it did great for about a half hour then a small leak appeared.i figured screw it i was done for the day.so the following sunday i took it back down and put another pump seal in making sure to lube the seal and the shaft of the converter put it back up and ran it.did great for 5 or 6 hours then again a leak appeared funny thing is no leak while running only when u shut it down.PLEASE HELP!!!![:@][:@][:@][:@][:@]
Old Jan 20, 2007 | 07:59 PM
Rizza757's Avatar
Rizza757
Default RE: front trans pump seals Help!!!
problem solved converter had small leak in weld
mtgldr
Feb 3, 2024 09:00 PM
zsmart
Convertible Tech
Feb 29, 2016 08:33 AM
TfcCDR
Sep 14, 2015 12:08 PM
97SN95GT
Sep 13, 2015 09:45 PM
raleigh05GTO
Sep 4, 2015 07:09 AM
