Annoying grind
Old Jan 14, 2007 | 09:45 PM
Telly's Avatar
Telly
Default Annoying grind
I have a 99 Cobra with about 95000 miles on it. I had a SPEC clutch and billet aluminum flywheel installed in it about 9 months ago. Just recently my car has starting making a grinding/whining sound when the clutch just starts to engage (first gear or reverse) It usually happens when the engine is cold. The sounds seems to be coming right up from under the center console. I've taken my car to the original shop and another shop and they both said that the clutch was fine. Help please! Thanks for any advice.
T
Old Jan 14, 2007 | 10:40 PM
GreyStang's Avatar
GreyStang
Default RE: Annoying grind
Well the only thing around the console that can make a grinding noise is the tranny gears,. does it make the noise while you're putting it into 1st or reverse? Or after you've already picked the gear and are releasing the clutch to get the car moving?
Old Jan 15, 2007 | 12:37 AM
Telly's Avatar
Telly
ORIGINAL: GreyStang
It happens then, yes. The sound it makes seems almost impossible to describe. One thing I know for sure is that it is nothing like the sound of grinding gears. Thanks for the help.
Old Jan 15, 2007 | 03:20 AM
Li0nHart's Avatar
Li0nHart
how 'bout the throwout bearing.....
SSG Steggy
3.7L V6 Technical Discussions
Nov 5, 2015 03:09 PM
KingRando
Oct 2, 2015 08:06 AM
JDWalton
Sep 24, 2015 08:47 PM
degner122
Sep 16, 2015 07:09 AM
tmdm
Sep 4, 2015 06:45 PM
