What determines "points" on a roll cage?
Old Jan 17, 2007 | 01:40 AM
kartracer55's Avatar
kartracer55
Default What determines "points" on a roll cage?
Can somebody explain the difference between, say an 8pt and a 12pt cage?
Thanks
Jim
Old Jan 17, 2007 | 04:17 AM
RyansQuick6's Avatar
RyansQuick6
Reverse Gear Member
Default RE: What determines "points" on a roll cage?
Chassis mounting points.
Cage regs are more than mounting points though. Crossbars and such have to be in certain places in relation to the driver and such. Depending on where you race the rules are strict and complex or pretty laid back all the way to non-existant.
Ryan
Old Jan 17, 2007 | 02:53 PM
StangChik's Avatar
StangChik
wow an 8 or 12 point....i think most of them are 4 or 6.
Old Jan 17, 2007 | 10:05 PM
JD1969's Avatar
JD1969
Pro. B.S. caller outer
ORIGINAL: StangChik
The faster the car is the more "points" the rules will dictate. 4 and 6 point are really refered to as roll bars as they don't have a halo loop above the driver. Basicly a point is anyplace the bar touches the floor, frame or chassis.
You can get an idea from this.
http://www.swracecars.com/roll_bars.asp
Take that 10 point and extend two bars through the fire wall and have them tie into the front frame rails and you have a 12 point.
jwog666
Dec 27, 2021 08:09 PM
flash_xx
Oct 16, 2015 07:23 AM
Explosive
Oct 2, 2015 07:45 AM
uedlose
The Racers Bench
Oct 1, 2015 08:31 PM
nmra1965
Other Professional Racing
Sep 26, 2015 10:46 AM
