Urethane or Solid Motor/Tranny Mounts
Old Jan 20, 2007 | 05:41 PM
KillSwitchNY's Avatar
KillSwitchNY
Default Urethane or Solid Motor/Tranny Mounts
Looking to stiffen up my mounts but im not sure which way to go. Is there excessive vibration or any downfalls to using solid mounts?? i put multiple selection on the poll in case you want to mix and match the motor or tranny mounts. thanks!
Old Jan 20, 2007 | 11:33 PM
RyansQuick6's Avatar
RyansQuick6
Reverse Gear Member
Default RE: Urethane or Solid Motor/Tranny Mounts
Unless it's strictly a race car, stay away from solid, you will hate life. Poly is a little more stiff than rubber, so naturaully it will have slightly more vibration.
Ryan
Old Jan 20, 2007 | 11:48 PM
Li0nHart's Avatar
Li0nHart
solid suck unless you are running strictly race...the reason you see so many of em on ebay is that they are cheap to make...i bit more is involved making rubber or poly...go with rubber if you re mainly going to be cruising...
Old Jan 20, 2007 | 11:50 PM
Li0nHart's Avatar
Li0nHart
..oh forgot..if you go with rubber or poly engine mounts and a solid tranny mount ..you risk cracking your bell housing...
jwog666
Dec 27, 2021 08:09 PM
baddog671
Jul 26, 2016 01:20 PM
UrS4
Oct 3, 2015 06:23 AM
Explosive
Oct 2, 2015 07:45 AM
lincolnshibuya
Sep 24, 2015 10:46 PM
