Better Brakes = Better Launch?
Old Oct 5, 2004 | 09:09 PM
Acer2428's Avatar
Acer2428
Site Mod
Default Better Brakes = Better Launch?
Let me know if I'm right on my theory here....
This applies to auto's only.
Since I have 18" wheels I can fit farely large brakes back there. If one were to get said upgraded brakes, bigger calipers, rotors, hi-po pads, would this hold the wheel in place enought to get another 400rpms or so before spinning?
It's attempting to do the same thing as a higher stall, but on a budget.
So, does better rear breaks = better launch?
Old Oct 5, 2004 | 11:15 PM
Dan04COBRA's Avatar
Dan04COBRA
Default RE: Better Brakes = Better Launch?
It'll probably make a difference so minimal you'd never notice it. If you pay for a complete brake job, that could possibly come out to be the same or even more expensive than a converter install.
Old Oct 5, 2004 | 11:25 PM
Acer2428's Avatar
Acer2428
Site Mod
I'd do it myself and it would just be the rear brakes. I figure anything less than another 400rpms or so would be a waste. For the $1,200 that a converter costs, would a PI upgrade be a better idea or a higher stall?
Old Oct 5, 2004 | 11:42 PM
Dan04COBRA's Avatar
Dan04COBRA
A PI upgrade is easily the best thing you can do for your car. You have higher compression stock, just a PI head & cam swap alone could break you into the high 13's with your automatic. The higher compression will help squeak out a few more ponies, but won't be all that friendly to boost.
You would want to go all 4 corners if you upgrade the brakes. Your *** end would slide out anytime you had to stop quickly. On the street, you want your brake bias to be much stronger in the front than the rear. It just doesn't make any sense to do it.
Old Oct 6, 2004 | 12:25 AM
Acer2428's Avatar
Acer2428
Site Mod
All I needed to hear!
Once I do gears and see about a side exhaust I'll look into the $1300 headswap kit and another $500 or so for cams.
Old Oct 6, 2004 | 08:48 PM
vfast's Avatar
vfast
I ♥ Acer
THE CONVERTOR would be the way to go..don't know how you got 1200 for it..a shift kit/chip and the convertor and cooler will help your launches to about .25 sec ... learn to plant the power you have first
Old Oct 6, 2004 | 08:51 PM
Acer2428's Avatar
Acer2428
Site Mod
That would eb a $700 converter + install...
Old Oct 6, 2004 | 10:38 PM
vfast's Avatar
vfast
I ♥ Acer
Edge Racing Converters Price List
(List effective until 6-04)
If you do not see the performance converter for your application simply email or call for a quote. Pricing is subject to change.
This list includes the most commonly sold products.
If your application is not listed give us a call. Chances are we DO build what your looking for!
"Work Horse" - Configured for applications where "Brute force" is an issue.
Extreme Duty and Low Stall for all applications - Call for quote
"Mild Street Edge" - Most of this series is limited to a maximum "True Stall" setting of 26-2800 rpm and designed for use in performance street applications with 450hp or less.
TH350, TH400, PowerGlide - 224.50
C-6, C-4 - 254.50
727, 904 - 259.50
700r4, 4L60 - V8 w/lock up - 324.50
- LS1 w/lock up - 394.50
- V6 w/lock up - 324.50 * this unit can be configured for stall math as high as 2800rpm
AOD w/lock up - 324.50
AODE / 4R70W w/lock up 374.50
E4OD - 399.50 or 499.50 w/billet cover
a500(42RH/RE) / a518 (46RH/RE) - 324.50
618HD (47RH,RE) - 474.50 or 594.50 w/billet cover
4L80E - 399.50
*** Ask about upgrading your lock up friction to the "high carbon" for only 30.00 ***
"Street Edge" - Custom tailored for your application so stall math is your choice! 2200-5600+
TH350, TH400, PowerGlide - 450.00
C-6, C-4 - 465.00
727, 904 - 455.00
AOD - 495.00 with all lock up upgrades or configured as a non lock
700r4, 4L60E V8 - 525.00 with all lock up upgrades or configured as a non lock
LS1 - 625.00 with all lock up upgrades or configured as a non lock
V6- 440.00 with all lock up upgrades or configured as a non lock
"Pro Edge" - Configured for your specific combination. 2200 to 6000+ You decide! For super charger, multi stage nitrous, trans brake and high torque track applications.
TH350, TH400, Power Glide - 650.00
C-6, C-4 - 665.00
727, 904 - 655.00
AOD - 695.00 with all lock up upgrades or configured as a non lock
700r4, 4L60E V8 - 725.00 with all lock up upgrades or configured as a non lock
LS1 - 825.00 with all lock up upgrades or configured as a non lock
V6 - 640.00 with all lock up upgrades or configured as a non lock
Please inquire by phone or Email for current build time
All units are custom configured and assigned a serial number for later reference.
Custom configuration means "NO PART NUMBERS"
We now carry a full line of performance transmission parts, shift kits and transmission coolers for every application!
Inquire for pricing.
Email or call with questions EdgeRacingConverters
1-888-350-EDGE
or 805 520 8528
vfast's Avatar
vfast
I ♥ Acer
mmmmmmmmmmmmmmmm
Old Oct 7, 2004 | 12:31 AM
Acer2428's Avatar
Acer2428
Site Mod
Thanks man.... I suppose I'll call around and see how much the install would run me....
I think gears are going to be close to $500, so as long as the install isn't more than $300 (I think it will be) I should be ok.
P.S. Can one switch out magnaflows for magnapacks using the same tubing/clamps or do they have different case legnths?
Thanks.
TCStangerv6
Oct 11, 2015 05:57 PM
Matt's 95 Stang
Oct 5, 2015 07:16 AM
guitarman376
Sep 30, 2015 05:54 PM
Sep 25, 2015 06:42 PM
ThatJuanStang
Sep 25, 2015 08:01 AM
