EXHAUST
Old Jan 23, 2007 | 11:25 PM
351W THUNDER's Avatar
351W THUNDER
Default EXHAUST
ok i have shorty headers using 2 1/2 304 stainless tubing straight duals with magnaflows that r 2 1/2 pipe with 4 inch OD paking 14 inches long straight threw.. the motor is a 351w.. how is it going to run.. do i need somthing thats not straight threw to give me back pressure???
Old Jan 23, 2007 | 11:40 PM
GreyStang's Avatar
GreyStang
Default RE: EXHAUST
That all sounds about right. Do you have a crossover X or H in the pipe setup?
Old Jan 23, 2007 | 11:50 PM
351W THUNDER
Default RE: EXHAUST
nah its straight 2 pipes.. why is doing they H or w.e make it better .. is it going to run good tho with the straight threw magnaflows.. i hear people saying im not ganna have back pressure and its ganna run like ****
Old Jan 25, 2007 | 12:04 AM
351W THUNDER
Default RE: EXHAUST
Old Jan 25, 2007 | 12:14 AM
Colorado_Mustang's Avatar
Colorado_Mustang
Default RE: EXHAUST
Is your exhaust going over the axle? The pipe will provide plenty of back pressure. A little restriction will increase your low end response.
I run dual 2.25" pipes into open turbo mufflers that dump before the rear axle. Runs great.
Old Jan 26, 2007 | 09:56 PM
351W THUNDER
Default RE: EXHAUST
no be4 the axle and im just dumping them right out to the ground with a little 45 Deg
Old Jan 28, 2007 | 11:24 PM
gspfunk's Avatar
gspfunk
Default RE: EXHAUST
Running a crossover pipe equalizes the exhaust pulses from both banks and helps w/ scavenging, which produces more power. Your setup doesn't sound like it will have much backpressure if your dumping them after straight-thru mufflers.....that will give you more top-end hp, but your low-end tq will most likely be pretty bad.
Dokilar
15
Oct 16, 2015 08:13 PM
Sep 30, 2015 12:39 PM
junior04
Sep 28, 2015 10:53 AM
DtRockstar1
Mustang Videos
Sep 27, 2015 07:46 PM
Sep 24, 2015 09:18 PM
