Big Brake Kit Question
Old Jan 27, 2007 | 05:06 PM
Rook6's Avatar
Rook6
Default Big Brake Kit Question
Honestly, is there really that much of a difference in performance between 13" and 14" brakes that warrants the 14s being double the price? Same question about 2-6 pot calipers, as well.
Old Jan 27, 2007 | 06:20 PM
1Bad302Stang's Avatar
1Bad302Stang
Default RE: Big Brake Kit Question
It will shorten your breaking distance a considerable amount. Unless your gonna be auto-crossing the car then I wouldn't spend double the money to go to a 14 in rather than the 13in setup.
Old Jan 28, 2007 | 04:14 AM
RyansQuick6's Avatar
RyansQuick6
Reverse Gear Member
I have the 13" front and rear setup, and I have zero braking problems. I personally do not see the advantage to that extra inch of diameter. I would imagine that a 13" kit with bigger calipers would work well and probably not cost as much, but I've never felt the need to research it.
If I were to go with some truly unreal brakes, I'd get the SSBC kit with the 8 piston calipers.
Ryan
squishbang
Sep 7, 2015 07:57 PM
CarrieS
Sep 1, 2015 01:00 PM
Faolan65
Aug 27, 2015 06:40 AM
Faolan65
Arizona Regional Chapter
Aug 25, 2015 09:24 AM
StangMuscle
Aug 12, 2015 07:27 AM
