Electronic Problem??
Old Jan 27, 2007 | 08:23 PM
paulfm5.0's Avatar
paulfm5.0
Default Electronic Problem??
My 95' 5spd. 5.0 has been completely cutting out while cruising in gear. The car will completely shut off, and i'll keep rolling while the check engine light comes on and then one or two seconds later it will come back on and i'll keep cruising at the same rpm's with no problem. The car will do this at completely random times sometimes after rolling to an intersection with the car in neutral. When the car is idling at an intersection i can hear the fuel pump whining up and down to the pattern of the blinker which sounds like the car doesn't even have enough voltage running to power everything effiiciently. I know my way around cars but i am left in the dark with this problem becauses of how random it is. Any help to diagnos the problem or suggestions would be appreciated, thanks
Old Jan 27, 2007 | 08:31 PM
corvetteguy's Avatar
corvetteguy
Default RE: Electronic Problem??
Chrck fuel pump relay
For $12 replace it.
Seanam
Oct 4, 2015 10:15 AM
stangin1996gt
Sep 21, 2015 11:01 AM
Big Al's 03
Mach 1 Section
Sep 21, 2015 07:59 AM
yourmom6990
Sep 14, 2015 10:52 PM
zanemoseley
Sep 6, 2015 12:58 PM
