car will not shift pass 1st
Old Jan 30, 2007 | 10:22 PM
8892mustang's Avatar
8892mustang
Default car will not shift pass 1st
i have a 92 ford mustang 302 eng. but the other day i was returning home and the car just did not want to do any more than 20mph, i checked under the hood anddiscovered that the linkagewas disconnected from the throthle body i connected it , car worked fine , now its doing the same thing. added some fluid to the tranny but it still will not shift.
Old Jan 30, 2007 | 10:51 PM
Archion's Avatar
Archion
Default RE: car will not shift pass 1st
on an AOD? if it is, and the tv cable was disconnected, expect a rebuild or replace. you can cook an AOD in nothing flat that way.
Old Jan 30, 2007 | 11:12 PM
8892mustang
how can i really tell if it is actually burnt
Old Jan 30, 2007 | 11:21 PM
Archion's Avatar
Archion
pull the stick and smell the fluid, if its really cooked you'll know it, but the small cable that goes from the tb to the side of the trans is the throttle valve cable, it controls the shift and operating pressures in the trans. It has a small grommet on each end which is usually the issue. One.95c grommet can cause a whole lot of trouble.the first thing to go would have been O/D usually, followed by everything but 1st and rev. If its only slightly burnt you may be able to get away with a soft parts rebuild on the trans. as long as there is no hard parts damage its relatily inexpensive. The best thing to do would be get it to a REPUTABLE trans shop and have them check it out.
Figure8allday
Aug 22, 2015 11:11 AM
antipeterleague
Aug 18, 2015 01:50 PM
92 5.0stang
Aug 13, 2015 06:46 AM
Milan Dragway
Aug 12, 2015 03:43 PM
