Damp footwells solution?
Old Feb 2, 2007 | 05:18 PM
buddha211's Avatar
buddha211
Default Damp footwells solution?
My car got a bit wet the other weekend during a rainstorm. The parking lot flooded overnight and seeing that the water was continuing to rise I decided to drive to higher ground. When I got in the car I discovered nearly an inch of standing water in the bottom of the car. I've had the windows open for almost 2 weeks now (under a car port), but with the rainy/humid/cold weather we've been having here lately its not drying very fast. I use teh shop vac on it every day but is seems most of hte moisture is in the padding beneath the upholstery. Is there something I can put on there to help draw the moisture out? I've thought about some activated-charcoal cat litter, but was wondering if anyone had anything more car-specific that could help. (No noticeable mildew yet, I've made it a point to keep the windows open at all times)
Old Feb 2, 2007 | 06:06 PM
BraMas's Avatar
BraMas
Default RE: Damp footwells solution?
I would get some fans blowing on the carpet. And there is a product called Damp-Rid that you can put it in your car also. I actual store my car with this stuff in it.
Damp Rid website
Old Feb 2, 2007 | 06:38 PM
buddha211's Avatar
buddha211
Thanks, I'll look into the DampRid stuff. The fans are impractical due to the fact that I live in a second story apartment with no external outlets.
Old Feb 2, 2007 | 09:24 PM
BraMas's Avatar
BraMas
Also with your car so new it seems like it would be covered under your insurance policy. That way you can have it professionally cleaned
Old Feb 3, 2007 | 12:40 PM
koesterca1's Avatar
koesterca1
Ive used the Damp Rid stuff before, and it works great.
Old Feb 3, 2007 | 09:07 PM
00perfredgt's Avatar
00perfredgt
I would pull up the carpet and padding, and let it dry out. You might get a mildew smell if you don`t.
Old Feb 4, 2007 | 03:04 AM
kenv's Avatar
kenv
ORIGINAL: 00perfredgt
+1 You will play hell trying to get rid of that smell once it gets in there. Also you run the risk of rusting/rotting out the footwell area
mirandaandjimmy
Nov 16, 2015 08:51 AM
fastbackford351
Oct 1, 2015 12:24 PM
Colin Ringle
Sep 15, 2015 09:27 PM
amandahchase
Sep 3, 2015 10:09 AM
