Power Window fix?
Old Oct 15, 2004 | 04:50 AM
94BOOSTDCobra's Avatar
94BOOSTDCobra
Default Power Window fix?
Anyone ever fix a power window problem?
On my 94, the passenger side window has all the sudden refused to go back up. Is there a temporary fix I am un aware of the get the damn thing back up? How hard is it to fix this?...any help
Old Oct 15, 2004 | 06:32 AM
e40water's Avatar
e40water
Default RE: Power Window fix?
Yes you can ge the window back up, What you need to do is remove the door panel inside youre car with the motor that has stoped working. their should be a metal bracket, with a nut on it, undo the nut, Then bracket should pop off then with the door opened use both hand on each side of the door window glass pull the glass up, then put the nut on the bolt and bracket theres youre window up.
Good Luck.
SSRFUZZY
Members Other Vehicles
Jan 6, 2016 08:22 PM
Pyrate Dave
Sep 10, 2015 07:30 PM
94stangnewbe
V6 General Discussion
Sep 7, 2015 07:39 PM
zanemoseley
Sep 6, 2015 12:58 PM
cbird1177711
Sep 2, 2015 08:51 PM
