Having a little problem
Old Oct 22, 2004 | 11:29 PM
Chopper's Avatar
Chopper
Default RE: Having a little problem
The anti freeze smell could be coming from the weep hole in the water pump.It's there to let you know that the seal is bad and the pump needs replaced.Look for stains around this hole.Sometimes it's on the top of the pump and sometimes it's on the bottom.This job takes about 30 mins.
Old Oct 23, 2004 | 10:25 AM
vfast's Avatar
vfast
I ♥ Acer
reason #1025423 to buy a fox*L*
Old Oct 23, 2004 | 12:14 PM
roundman's Avatar
roundman
ORIGINAL: Chopper
I hope you mean looking for a leak takes about 30 minutes cause you sure as h**l ain't going to change the water pump on a 5.0 that quick! don't think it would be any easier on a 4.6 either but I ain't never done one on a 4.6 so I'm not sure.
Old Oct 23, 2004 | 09:08 PM
vfast's Avatar
vfast
I ♥ Acer
damn I need choper doing my water pump changes I could get rich faster
Old Oct 23, 2004 | 09:49 PM
jdaniel's Avatar
jdaniel
I ♥ Acer
I was having the same problem with the coolent smell and coulndt find a leak anywhere on the coolant system. I took it to Ford and the put a pressure test kit on it and it held so many pounds for about an hour and a half. They said the coolant may be old and needing a change. I changed it and the smell was all gone.
P.S. Change it yourself... Ford dealers want like $150.00 just to turn a valve and let it drain and refill it. LOL@Ford!
Old Oct 23, 2004 | 09:52 PM
vfast's Avatar
vfast
I ♥ Acer
hey a man gotta eat
Old Oct 24, 2004 | 12:17 AM
STKClutch's Avatar
STKClutch
I took a hose with hot water washed beneath my car hasnt been a smell since....
But now I hear a little whining in 5th kinda like a little whistle?????? From the shifter
Old Oct 24, 2004 | 12:57 AM
jdaniel's Avatar
jdaniel
I ♥ Acer
Is it the stock shifter?
Old Nov 8, 2004 | 03:24 AM
STKClutch's Avatar
STKClutch
no I have the pro 50 short throw
Old Nov 9, 2004 | 10:56 AM
WorldMustang's Avatar
WorldMustang
ok the radio can be fixed with a noise reducer, a wire in device the keeps electric interferance from effecting your radio old technology to say the least. The Smell can be several things. One you thermaste is not opening and your overheating. 2 you have a leak in your heater coil, three your water pump is shot. Four you leaking out of one of the radator or heater hoses connectors and boiling off on contact. keep your eye on the guages and the water level.
[IMG]local://upfiles/10267/5FE49D10A932483D942EE0D6A295C12B.jpg[/IMG]
69Volunteer
Sep 30, 2015 10:39 AM
marc954
Sep 29, 2015 03:05 PM
marc954
Sep 25, 2015 06:48 AM
stangin1996gt
Sep 21, 2015 11:01 AM
Big Al's 03
Mach 1 Section
Sep 21, 2015 07:59 AM
