need help with radiator?
Old Oct 22, 2004 | 11:42 PM
Chopper's Avatar
Chopper
Default RE: need help with radiator?
Head gasket for sure[>:]Probably went when the car overheated the first time due to the fan not running.The aluminum heads on modern cars will not tolerate even one severe overheating episode.Warps and cracks are the result.Unfortunately both heads could be affected.Small imperfections can be milled out but cracks and large warps cannot.This will call for a replacement.Scrap yards might be a good place to start looking.Or if you are going to keep the car for awhile look to the aftermarket for some really good heads.
Old Oct 23, 2004 | 01:38 AM
cammedlx's Avatar
cammedlx
his mustang does not have aluminum heads stock
Old Oct 23, 2004 | 02:10 AM
luckythirteen13's Avatar
luckythirteen13
changing the head gasket is going to be very expensive if you dont do it yourself. it involves taking out the ac pump, alt. intake hose, intake manifold, exhaust manifold, fuel injectors and rails, that pipe that connects the two pipes in the back and probably more i cant think off. if the heads and block are ok, parts are cheap....a new gasket is $65ish but labor my be $1200. be sure you go some where you trust.
Old Oct 23, 2004 | 10:25 AM
vfast's Avatar
vfast
I ♥ Acer
no the water pump is locked up......you should have lost the belt to it by now
Old Oct 23, 2004 | 07:52 PM
JJ94GT's Avatar
JJ94GT
so u guys are suggesting that i need to replace/repair the head gasket? get new heads? and if so.. will that fix the fan?... probably the main reason why the head gasket needs to be fixed.
Old Oct 23, 2004 | 09:02 PM
vfast's Avatar
vfast
I ♥ Acer
replace the water pump first..I'm sure that is what caused this all in the first place......this car doesn't has a electric fan right?
Old Oct 24, 2004 | 03:26 AM
JJ94GT's Avatar
JJ94GT
the 95 5.0 has an electric fan, it is not belt driven.
Old Oct 24, 2004 | 04:08 AM
e40water's Avatar
e40water
these are things I would do to findout youre head gasket or head is cracked.
1.) pull youre oil dipstick out check and see if their is any yellowish flim in youre motor oil.
2.) Do a check on spark plugs see if they are coated with white deposits and get cyl compression checked.
3.) check all hoses upper and lower hoses / heater core hoses, frost plugs block etc.
4.) check for any coolant leaks on youre intake manifold.
Good Luck.
Old Oct 24, 2004 | 03:45 PM
JJ94GT's Avatar
JJ94GT
thanks guys i appreciate it
Granatelli Sales
Jan 20, 2020 12:34 AM
stangin1996gt
Sep 21, 2015 11:01 AM
Beerman309
Sep 19, 2015 01:16 AM
MusicCity615
Sep 12, 2015 07:05 AM
raleigh05GTO
Sep 4, 2015 07:09 AM
