front brakes locked up!!!!!
Old Feb 23, 2007 | 07:55 PM
NinetySixGT_Stang's Avatar
NinetySixGT_Stang
Default front brakes locked up!!!!!
well i was driving to my buddies house and he lives about 10 minutes away in stop n go, when i started noticing that my front brakes were sticking while i was driving. i first noticed it after getting gas as i would roll up to a stop i would stop abruptly rather than roll into a stop. then i noticed that my brake pedal felt different and made a funny clicking noise when i would depress it all the way. i continued to drive anyway. it began getting worse. as i drove, my brakes were pulling the car so i had to drive in second gear. i pulled over and the pads were on fire and smoking bad. does any one have any answers to why this happened and how to fix it?
Old Feb 23, 2007 | 08:43 PM
JH23's Avatar
JH23
Default RE: front brakes locked up!!!!!
was it both sides or just one side ?...you have a stuck brake caliper...time for a new one
Old Feb 23, 2007 | 11:31 PM
351W THUNDER's Avatar
351W THUNDER
the best way 2 do it and save money is right be4 u take it out for a spin rub some gasoline all over ur rotors and calipers it helps them out so much haha
Old Feb 24, 2007 | 01:22 AM
NinetySixGT_Stang
it was both the front brakes. the rear brakes were ok. someone told me it could be the proportioner that went bad and its send the wrong amount of fluid to the calipers. could this be it. after i led the fire from the brake pad go down and cool off a bit, i drove it and my brakes were freed up. now when i drive it up and down my street i can feel it starting to grab again when im stopping. please help. i dont like to see my stang in distress.
Old Feb 24, 2007 | 07:38 PM
corvetteguy's Avatar
corvetteguy
Don't soak it in gas, I understand it is not
a very good lubricant.
I would worry about the condition of the
rubber brake line.
You will need to push the caliper in.
Inspect the rubber piston boot.
Replace the pads.
Use brake grease on the rubbing metal
to metal parts.
Is it possible the pads haven't been changed
in a while and the pistons went out too far
and cocked?
SSRFUZZY
Members Other Vehicles
Jan 6, 2016 08:22 PM
maestro1024
Sep 21, 2015 02:40 PM
Sep 16, 2015 07:53 PM
Sep 8, 2015 11:50 AM
