Going for a drag look
Old Oct 28, 2004 | 01:18 PM
DaGGer's Avatar
DaGGer
Default Going for a drag look
ok well i want to give my car a bit of a drag look...i don't have the money yet i just wanted to find some info on it...now if i wanted the back end to be a bit higher and have bigger tires on it would this be good or bad...i mean i want a muscle look on my car and i personaly think that it would look really good this way...i just wanted to find out if this is good or bad.....is this a good idea or how hard...i just like the way it looks...also how would the ride be in it...like street driving and highway driving...well thanks for you feed back everyone
Old Oct 28, 2004 | 02:25 PM
roundman's Avatar
roundman
Default RE: Going for a drag look
the jacked up rear and nose down front end look is passe` nowadays, but to each his own I guess. easiest way to get this look is to lower the front end or use shorter tires up front, I guess, but be aware that this can limit the size of the tires you can run up front and still have full motion of the steering. it also changes the weight distribution more towards the front end and this can negatively affect both handling and braking too.
Old Oct 29, 2004 | 05:51 AM
94Cbra's Avatar
94Cbra
Actually if you get a good set of drag springs, with little tires in the front, the big fat tires in the rear should lift it up a little.
Old Oct 29, 2004 | 04:59 PM
cammedlx's Avatar
cammedlx
^^^^^some welds and spring's and volia!!!!! drag baby LMAO j/k
Florida Regional Chapter
Sep 30, 2015 08:04 PM
guitarman376
Sep 30, 2015 05:54 PM
Sep 15, 2015 07:34 PM
vintageaion
Sep 8, 2015 10:45 AM
