How do I get the rear piston back to fit new brakes
I have been changing brakes on car for years. I went to change rear brakes on my daughters 2000 V6 mustang (all disc brakes). When I went to use a c-clamp to push the piston back in it wouldn't go. Called the dealer and he said it screws back in because of the parking brake. I tried to use a screw driver but I couldn't get them to move. Do they turn in and do I need a special tool or socket to fit the piston to turn it back in? What are the correct steps to put the piston back so new brakes will fit? Thanks
RE: How do I get the rear piston back to fit new brakes
i believe autozone and like sell the tool as i recall
its a socket on 1 side and a special fitting on the other side any parts store that carries it should be able to tell you how it works
Thanks for all the help. I looked on ebay last night and couldn't find one. I searched about 10 different ways but I guess I didn't use the rightkeyword. Thanks for looking it up and giving me the link.
I have used three screwdivers: 2 vertically on each side index, and 1 horizontaly between the others to help turn. This always does the trick to scrape, smash and otherwise mame the technician...and occasionally helps the piston retract!
Find the tool if you can, but this will work with enough patients.
Troy
Troy
I checked the local Napa and Advance Auto.. No tool. Tried the screwdriver trick but busted some knuckles. I then borrowed the tool from a friend who is a mechanic. The driver side was turned out the whole way because the brakes were so low. what a beotch to get back in. The passenger side when pretty smooth. Thanks to all who responded.
NorthAmericanTuning
11-09-2016 11:45 AM
NorthAmericanTuning
03-18-2016 11:21 AM
Fast-Hands
08-19-2015 06:54 AM
