70mm tb vs. 75mm
Old Nov 2, 2004 | 08:22 PM
mdvaldosta's Avatar
mdvaldosta
I ♥ Acer
Default RE: 70mm tb vs. 75mm
don't worry I'll send you some royalties, nobody messes with tb's on auto engines, its called blueprinting in the kart engine world where every .5 hp counts - I understand what you mean though
Old Nov 3, 2004 | 11:58 AM
Redline03GT's Avatar
Redline03GT
Get the 70mm unless you plan on getting a supercharger, then you can upgrade it to a 75mm.
Old Nov 4, 2004 | 01:12 AM
Valek's Avatar
Valek
10-4 to that.
Old Nov 4, 2004 | 01:14 AM
Valek's Avatar
Valek
Get the Accufab plenum and 70mm TB. Best power gains.
ORIGINAL: Redline03GT
Old Nov 4, 2004 | 05:28 PM
vfast's Avatar
vfast
I ♥ Acer
most plenums are very close in hp..accufab just has to be one of the most expensive.....what is the maf size on your car....
Old Nov 4, 2004 | 05:35 PM
Bowdy04's Avatar
Bowdy04
I believe it is 80mm...its whatever comes stock on 04 GT's...I think i saw somewhere it is 80 though...I'm thinking about going with the Pro-M 85mm MAF...would that help out the gains of the TB and Plenum?
Old Nov 4, 2004 | 06:13 PM
vfast's Avatar
vfast
I ♥ Acer
if you went to any I'd go with a 2002 lighten 90mm it's a plug in for you ....they work great
Old Nov 4, 2004 | 06:38 PM
Bowdy04's Avatar
Bowdy04
ORIGINAL: vfast
where might i get one of those?? haven't seen a 90mm nor have i seen anyone on these forums using a 90mm...
Old Nov 5, 2004 | 12:13 PM
Redline03GT
I think pro-m has some.
Old Nov 5, 2004 | 02:55 PM
2000GT4.6's Avatar
2000GT4.6
I have seen dynos (many) that show the install of a plenum (C&L, accufab, whatever) around 5-10 RWHP. Then they swap out the 65mm T/B for a 70 or 75 and only gain 2-3 more RWHP.
The throttle body is not a very restrictive componet in a n/a GT, espcially one with no cams/head work. Whichver you buy will be fine, there will be virtually no difference in horsepower (although some people claim they feel a diff in "throttle response, probablyi just their imagination)
dubarado
Dec 23, 2015 01:16 PM
JT76
Sep 20, 2015 11:32 AM
01blackgtconv
Aug 10, 2015 01:25 PM
Redneck1465
Aug 8, 2015 10:39 PM
