advancing my timing
Old Nov 3, 2004 | 02:13 PM
Bowdy04's Avatar
Bowdy04
Default advancing my timing
what are the benefits of advancing my timing?? I have a predator coming in, and can do this...with my mods would this add hp's? What does it exactly do anyway??
Old Nov 3, 2004 | 03:35 PM
propellerhead's Avatar
propellerhead
Default RE: advancing my timing
Google'd it.
http://www.miata.net/garage/KnowYourCar/S10_Timing.html
In short, you are optimizing the combustion by taking the engine speed and the burn rate of the air/fuel into account. The net result is better performance.
Old Nov 4, 2004 | 10:58 AM
Bowdy04's Avatar
Bowdy04
so no negative side to advancing the timing??
Old Nov 4, 2004 | 10:59 AM
mdvaldosta's Avatar
mdvaldosta
I ♥ Acer
gotta run premium gas
Old Nov 4, 2004 | 01:38 PM
roundman's Avatar
roundman
biggest negative is you can go too far advanced and cause predetonation or pinging which can damage the engine. it will also cause harder starts and possible overheating problems but usually most don't go too far and have these problems. once you get the Predator, it advances the timing internally all the time and you will most likely have to set the base timing back to stock after you install it to prevent pinging and damage. and premium gas ain't cheap nowadays either. LOL
Old Nov 4, 2004 | 02:23 PM
Bowdy04's Avatar
Bowdy04
Yeah i'll have to run premium...gass prices SUCK!!!...i've read that the predator will not let you over adjust the timing though...so I won't have to worry about over doin it will I?
Old Nov 4, 2004 | 02:25 PM
Bowdy04's Avatar
Bowdy04
I think it will only allow adjustments up to 10% anyway...unless get a specific tune on it...
Old Nov 4, 2004 | 02:26 PM
propellerhead
ORIGINAL: Bowdy04
Where did you read that? I really doubt that statement. If you hear it ping when you accelerate, then back it off a little until it doesn't. It's not that scary.
Old Nov 4, 2004 | 05:33 PM
vfast's Avatar
vfast
I ♥ Acer
well running 93 isn't a must ..I use a hypertech mod on my truck say 91 +..I use 89 and never herd a pip
Old Nov 4, 2004 | 06:49 PM
offnet83's Avatar
offnet83
My timing was retarded all to hell, and I advanced it to 14.5 degrees or so and run 93 and I had a pretty good notable change in power.
mdj89
Sep 6, 2015 11:08 PM
cbird1177711
Sep 3, 2015 08:43 PM
Sep 2, 2015 08:40 PM
cbird1177711
Sep 2, 2015 04:12 PM
