Tranny Fluid
Old Mar 8, 2007 | 01:15 AM
00blackstang's Avatar
00blackstang
Default Tranny Fluid
Whats up guys, im lookin for the best manual transmission fluid out there. Any body know from personal use, or which they perfer. I want the shifts to be as smooth as they can. If you can get that from a fluid. Thanks
Old Mar 8, 2007 | 01:18 AM
sprostang's Avatar
sprostang
I ♥ Acer
Default RE: Tranny Fluid
Royal Purple synchromax.
Old Mar 8, 2007 | 01:33 AM
Colorado_Mustang's Avatar
Colorado_Mustang
Depends on the tranny. Put synchromax in a toploader and you'll be replacing it quickly.
Amsoil makes a series of different oil that will cover the range of fluids required for different transmissions. Plus, you'll get a warranty directly from Amsoil.
Old Mar 8, 2007 | 02:44 AM
mustangzrx's Avatar
mustangzrx
I have a 2003 GT with a Tremec TR-3650 transmission. I just went out and bought four quarts of synthetic Mercon fluid because that's what my owner's manual recommended. I haven't changed the fluid yet. Now I've ran across the following quote from this link:
http://en.wikipedia.org/wiki/Tremec_...0_transmission
"TREMEC engineers have recommended Texaco-Havoline Dexron III/Mercon Non-Synthetic ATF. The most recent Ford owner's manuals specify 3.17 quarts of a non-synthetic Mercon ATF. There has been a significant amount of confusion regarding the proper capacity and proper type of ATF for the TR-3650 which may have a correlation with a rather large number of complaints about notchy shifting, shift "nibbling", noisy synchros, and grinding gears."
Does anyone have any constructive input? I intend to change my fluid soon and would like to put the right stuff in there.
GS
Old Mar 8, 2007 | 10:49 AM
Chopper's Avatar
Chopper
I used Red Line fluid in mine.It still shifts harder when cold but you shouldn't be hammering a cold engine anyway.
Old Mar 8, 2007 | 09:28 PM
Colorado_Mustang
I'd like to see where Tremec engineers made a recommendation for non-synthetics. The factory filled 'er up with synthetic in the tranny and rear end....[&:]
Thunderball
15
Nov 22, 2015 11:49 PM
wraith777
Sep 28, 2015 10:49 AM
treesloth
Sep 28, 2015 07:03 AM
2poor4u2
Sep 26, 2015 11:08 AM
Sep 25, 2015 06:42 PM
