starter does not turn over when car is hot
Old Mar 10, 2007 | 09:24 PM
dkorenic's Avatar
dkorenic
Default starter does not turn over when car is hot
I have a problem that is driving me crazy.The car starts fine when cold but after driving the car for about 10 miles and it gets nice andhot and then you park it for a couple of minutes the car will not start. When I say doesn't start, I mean it doesn't even turn over. If you leave it set there for about ten minutes or so, itstarts right up.
Any ideas?
Old Mar 10, 2007 | 09:41 PM
sprostang's Avatar
sprostang
I ♥ Acer
Default RE: starter does not turn over when car is hot
Sounds like the starter is getting too hot and needs to cool down. Goes out on overload.
Do you have L/T headers?
Old Mar 11, 2007 | 08:59 PM
351W THUNDER's Avatar
351W THUNDER
is it old.. mine did the same thing,. its time for a new starter.. the spring that pushes the gear into the flywheel is getting stuck and spinning the crap out of ur starter.. run ur car for a while and feel ur starter.. if it is to hot to touch then its junk. if its not then idk
Old Mar 12, 2007 | 01:30 AM
Li0nHart's Avatar
Li0nHart
A weak battery can cause those symptoms as well. A cold engine is easier to crank as tolerences are looser.
Old Mar 19, 2007 | 12:37 AM
kenv's Avatar
kenv
If it a carbed car, It could be vapor lock. Make sure its not running lean. This used to happen a lot with the cars from the 70`s/mid 80`s
Old Mar 19, 2007 | 04:32 AM
NeoTokyo's Avatar
NeoTokyo
sounds like a starter prob for sure, odly enough my Chevelle and El-Caminog had this problem all of the time, and even with new starters.
I happen to have a new starter from an 03' Mach1 for sale if your interested. It has about 10 starts on it and then thats it. It was a ford test car and wrecked in the rear. I got the front half, I also have other parts too.
I would strongly suggest a new starter from a store with a warenty though, just for that purpose, so go get a store bought one to be safe
-Eric-
Old Mar 19, 2007 | 07:54 AM
jrhaden's Avatar
jrhaden
OK Ok it is either A- - -Starter bit the dust or B- - - Starter Solenoid bit the dust.
xbmx89
Texas Regional Chapter
Nov 10, 2015 10:43 PM
KEM Motorworks
Aug 14, 2015 10:13 PM
92 5.0stang
Aug 13, 2015 06:46 AM
Milan Dragway
Aug 12, 2015 03:43 PM
Itstbrown
Aug 9, 2015 03:49 AM
