Clutch Height
Old Mar 15, 2007 | 09:23 PM
00blackstang's Avatar
00blackstang
Default Clutch Height
Whats up guys, My clutch Connects really high,like just about at the top.i was told it should b somewhere in the middlewhere it should connect. How do i adjust that so it connects there, or even is there a way to make it connect there?
Old Mar 16, 2007 | 12:21 AM
00blackstang
Default RE: Clutch Height
anybody know?
Old Mar 16, 2007 | 12:29 AM
00blackstang
sorry let me rephrase that, the height of engagment
Old Mar 16, 2007 | 12:25 PM
Jfsram's Avatar
Jfsram
If it's really high it could be worn.
I'm not sure if the 00's still use the plastic adjustable quadrant. If you, flick the pedal upwards with your foot. It will take up any slack in the cable, although, high pedal most likely means no slack.
The only downfall to a high pedal is it may be adjusted too tight and the clutch will slip. Too tight is also hard on the throwout bearing because it's constantly loaded.
Mine engages about 2/3's the way up.
Thunderball
15
Nov 22, 2015 11:49 PM
junior04
Sep 28, 2015 10:53 AM
MacSerio
Sep 27, 2015 01:05 PM
ccdguy
Sep 19, 2015 05:20 PM
MasterLanMan
Sep 13, 2015 08:21 PM
