CAR Stalls Help
Old Nov 9, 2004 | 11:36 PM
sevendustx's Avatar
sevendustx
Default CAR Stalls Help
Ok I been having this problem for a couple of weeks now on my car (1995 Mustang 5.0 ). As im driving down the road my car just dies. Sometimes its starts right back up and will run fine for a couple days. Other times I have to wait several mins before it will start. Well, the coil does not give spark to the distributor. I changed the coil but the problem still occurs I came to the conclusion it might be my distributor or a relay. Not sure witch relay it might be or if the distributor can be the cause. I will appreciate any insight. Thanks[:@]
Old Nov 10, 2004 | 11:42 AM
jdaniel's Avatar
jdaniel
I ♥ Acer
Default RE: CAR Stalls Help
I would replace he distributor. Thats the next easiest thing to replace and they shouldnt cost much either.
Old Nov 10, 2004 | 12:43 PM
roundman's Avatar
roundman
it could be the TFI module that plugs into the distributor. I would get this checked before I spent money to replace the distributor.
Old Nov 10, 2004 | 04:22 PM
vfast's Avatar
vfast
I ♥ Acer
all but everyone needs a nice billet msd dist..reman
Old Nov 10, 2004 | 05:18 PM
sevendustx's Avatar
sevendustx
Whats the TFI module and where is it located? The connector to the distributor goes right to the engine harness. I cant trace it unless i ripe the plastic off.
Old Nov 11, 2004 | 02:56 AM
pacepony's Avatar
pacepony
i had a problem like that and my coil was getting too hot. i had to put a voltage reducer on my wires but then again mine is a 79
Old Nov 11, 2004 | 07:18 PM
roundman's Avatar
roundman
ORIGINAL: sevendustx
TFI = thick film ignition and the module is the large gray plug that plugs right into the base of the distributor with several wires coming out of it.
djbigskrilla
Sep 20, 2022 01:04 AM
92 5.0stang
Aug 13, 2015 06:46 AM
Milan Dragway
Aug 12, 2015 03:43 PM
stanngg
01blackgtconv
Aug 10, 2015 01:25 PM
