power door locks
Old Mar 25, 2007 | 07:59 PM
yealo gt's Avatar
yealo gt
Default power door locks
I have a 1993 GT. Both power door locks are stuck in the unlocked position. When I try to lock the doors with a key or by pressing the lock button , neither side will lock. I checked for current at the doorswitches and both sides are hot. I don't know if the problem could be a relay switch or if the car even has one or where it might be located.
Thanks for any info you can provide
Old Mar 26, 2007 | 09:26 AM
corvetteguy's Avatar
corvetteguy
Default RE: power door locks
I would pull the fuse.
Then try the key.
If it works, then there is a short in the
wireing keeping the power applied to the
unlock relay.
If the power is left in this mode you are
just waiting for the enevitable fire.
If the key won't work when power is removed
you might have a mechanical blockage in both doors.
Old Mar 26, 2007 | 12:29 PM
TwotoneVert's Avatar
TwotoneVert
It could also be the actuators. My passenger side is froze, and will not work. You can purchase a kit to replace them for 60.00. The kit will do both doors. I dont remember the vendor, but you can check the first couple of pages in MM&FF, middle of the page.
JoshyGT
Sep 19, 2017 08:52 PM
SSRFUZZY
Members Other Vehicles
Jan 6, 2016 08:22 PM
accarter
Sep 21, 2015 11:56 PM
cbird1177711
Sep 2, 2015 08:51 PM
SYNY5TER
Sep 2, 2015 01:35 AM
